"And I am concerned about the state of the immobiliser dashboard warning light! If it does not stay lit when ignition is switched on, then all is probably well in that department."
No dashboard immobiliser light at any stage since i bought he van, doesn't come on ever.
However.... i did get it going perfectly by by-passing the Immo and shut it off.
Started it again and ran it for a few mins , no issues
I thought about the result , replaced the "hotwire" with a very light wire and it started again and a little smoke appeared,
so i removed my work.
Oddly there was now a short where there wasn't before.
Everything works except the car won't start and there are no blown fuses.
Wiring in that area does not appear damaged.
Have i fried the ECU?
New codes,
PO351 ignition coil ,primary circuit.
PO201 Injection circuit open.
Might a new working set of ECU/BSI/Lock IMMO solve my problems/
Or do i just store fencing stuff in it?
New codes,
