Nice, it's half price at the moment. I've have the equivelant cheap as merde spanner set to the one aldi is selling. So I'd just buy one or two of the crappy ALDI sets (if require). And grind the 32mm down to 31 and the 30 down to 29mm See what I mean by needing lots of these cheap shitty spanners to modify!
Yeah I worked that out well didn't I .... would you believe that was deliberate Don't worry, I know what I meant .... I thinkHaving spent some time on the tools I'm intrigued as to how taking material off the jaws of spanners somehow reduces the gap size? Am I missing something here?
They must think people quite uninformed to make a claim like this about the lift.
I reckon you could buy 3 similar lifts for that price
If that bearing is in a blind hole/bore you can also try to pack the space behind it with grease and push a close fit dowel through the inner bearing race until it contacts the grease then whack it with a hammer. Not apeshit hard. The bearing should come out little by little (you need to repack the grease a bit to compensate for whatever will squeeze through the bearing). Cheap and effortless.
Some key points.
The grease needs to be well packed so there is no air trapped in, the dowel needs to be a close fit, you need to make sure it contacts the grease and (hopefully) the bearing is closed (shields/seals in place). Works even with the most stubborn bearings or even bushings like those in the flywheel (g'box input shaft pilot). The input shaft itself is very well suited to play the dowel in this case.
Just bought a decent brick cutter for a few big jobs coming up.
From Able Machinery - $950 - sounds expensive but cheap for one of these. Have bought Able stuff before, no frills Chinese made, but pretty rugged construction, semi-commercial use.
One would think it best to hire a brick cutter, but at $150 per day, I thought how pissed off I would be when I went down for the seventh day to hire one! Also then you are on a time limit every time, and loading on and off the trailer - no thanks.
I have this garden bed to edge (1st job), then the carport to be paved with probably about 100 pavers to be cut (2nd job) and then about 80 square metres of driveway paving with curved borders. Now whether or not I do it myself, or get a young fella to help me, still need a brick cutter.
When I went to pick it up it was in a bigger box than expected, lucky I took the trailer.
It is heavy, about 85kgs, needs 2 blokes to move it around.
I've got it set up under a portable gazebo and today used it for the first time. Cuts through these 80mm thick x 270mm deep concrete blocks with ease, although I did push it a bit too hard (see video) and it stalled, but recovered when load taken off. Have since cut quite a few blocks with a steady even light pressure and it does a great job.
Fordman commercial paving venture coming up? !
