Thanks Rob,
yep, the new ceramic mixer we picked up looks to have that spec - without resorting to the calipers....
Reeces had fittings for the fancy water tap we found for the water tank pump, 7/16" 24tpi. They said it probably came from a filter kit - plastic fittings they supplied are to suit a 1/4" LLDPE line. All cheap enough to toss if the flow rate turns out to be unsatisfactory.
We picked a Davey SJ35-04PC pump to feed it, and the toilet cistern if we have a mind to... hmm, might be a rebate for that....
cheers,
Bob
In actual fact, the thread of the fitting that screws in to the brass body of nearly all capsule type mixer taps is 10mm /1.0mm pitch. Taps are hard to come by.
cheers,
Bob
