Update....
*Grouting completed
*Schlitz.... that's not a bad idea. In our case, the main problem was getting the render to stick. I don't know why.
*SS. see photo a few posts back for the green tiles. They are circa 50s, I think. I found recently that if you want a 150mm square porcelain tile, you can have it in any color you like, as long as it's white. So I didn't match them, leading to the photo you can see.
*Graham: there is already a vertical hand hold. It is actually the vertical part of a redundant hand shower fitting. Mater reckons she prefers that to a horizontal one, so we are running with that. I put in plenty of fall, as it is conceivable that, being an open shower, water could fall as far as 1.5m to 'the right' as you look at the photo. So we gave the floor a dished profile left to right, and (of course) sloping right to left into the drain. It is about 25mm (maybe a tad more) below the level of the edges near the drain, which may be overkill, but of course, insufficient fall is a right PITA once it's baked into the concrete!
Graham, one last question if I may be so bold: the sodium silicate is quite viscous! It is just like it looked in the video, and forms the same 'skin', so I don't really doubt is correct. But, can you just confirm that I just coat the grout with the sodium silicate as-is, leave it for 6 hours ( as I think you indicated) then clean off the excess? Thanks
All up, I cannot express how relieved am I that the project has reached this point!
Aside from the sodium silicate matter, the tidy up tasks on a later visit will be to put in a fixed/flexible shower head combo, and I am going to paint the floor and lower green tiles with White Night white tile & laminate paint.
*Grouting completed
