With that rusted out rear end and no back suspension at all?Yeah I realised as soon as it was running what I'd done, I'd set the timing statically at the point where the points closed (rather than opened). If I'd looked down there with a light when I was setting the timing, I would have seen I was on the wrong side of the dizzie cam.
Now I know the motor seems .... well amazingly good I'll see if I can get a 5minute drive around the yard to see if the gearbox has a good 2nd gear synchro (I'm thinking it might be as good as the motor). I'm still just amazed how clean inside that motor is.
BTW - if it was in top gear when you were trying to start it, was it in top gear when you were dragging it and winching it? Had you already been turning the motor over without realising? Actually, you would have realised when you hand cranked it, so perhaps not...
