It'll buff out.
... but will it run???
They didn't promote the onboard petroleum based liquid rust prevention qualities afforded by LHM and the bi modal systemic distribution network.
It seems to have an inbuilt refreshing mode as well utilising both passive gravity and a higher pressure energised system for distribution and penetration.
Xantias took the philosophy even further with a dedicated driver's floor rust prevention program distributed by the brake master valve body.
I believe the reason they kept quiet was fear of litigation from the British over patent infringement on their similar engine/gearbox/diff based system.They didn't promote the onboard petroleum based liquid rust prevention qualities afforded by LHM and the bi modal systemic distribution network.
I'd be more worried about redback spiders.View attachment 220923
I wonder what the chances of getting these recessed spark plugs out is if they have been in there for 40+years.... and the scuttle plug isnt in on No 4. Fun and games for sure
Shane, I have but one question! WHY?
Is the roof panel any good for your 63?
Yeah I realised as soon as it was running what I'd done, I'd set the timing statically at the point where the points closed (rather than opened). If I'd looked down there with a light when I was setting the timing, I would have seen I was on the wrong side of the dizzie cam.Remarkable! That encourages me to have a crack at the pommy straight 6 I've got in an Austin A90. It's only been sitting for about 26 years (and it's under cover).
What were you doing down the side of the motor, after tightening loose coil connections, and prior to it starting? Did you have the dizzie clamp loose enough that you could adjust the timing on the fly?
