Friction modifiers are NOT friction increasers! That would result in the box lunching itself.
I'm decrying the diesel treatment, most Xantiæ I know of that had this done, suffered a number of failed hoses afterwards. Including mine!
I thought the issue was that if the ATF was too slippery the wet clutch(s) would slip (OK motor bikes have multiplate wet clutches bathed in straight engine oil, but they aren't as heavy).
Re. the leaks - can't say I'm surprised - diesel is a pretty good solvent!
What I am looking for is the cheapest fluid that I can use to temporarily fill up an old Xantia (which has leaks I can't be bothered fixing - which is why the stuff needs to be cheap!) so I can move it. Rabbits are living under it, and with the car down to it's bump stops the dogs can't follow them under it !!
It would be preferable if the stuff does no harm as it's a VSX and packed full of useful stuff. OK - LHM's the best, but ATF is half the price and available in 4 litre containers anywhere! Diesel would be even cheaper, but the leaks are bad enough thanks! If Dex II is OK I'll use that - don't like the idea of having anything else around that might accidentally find it's way into a 605 auto trans!
Alec
