The hydraulics on my 1995 Xantia VSX are in a bad state. The ride goes hard at times, the rear jumps up suddenly after starting the car for the first time for the day. I did replace the rear height corrector with another (which was just as good/bad). Today I bit the bullet.
I emptied out the old LHM. Cleaned the filters. In the process of removing the LHM tank, I broke one of the 20 year old rubber return lines. Fortunately, I had the solution on hand. To add a few inches of new rubber tubing to the old hard rubber tubing, I used a Pirtek P7R 1/4" to 3/16" brass reducer.
This is a great lifesaver. The old rubber is rock solid, but the smaller barb penetrates it without splitting the rubber. It is then clamped. The larger barb slips easily into the new rubber and is also clamped.
After 2 CXs and 2 BXs, I am continually amazed how badly designed the Xantia LHM container is to remove, empty and clean.
Rant over. After speaking to Father Goose, he recommended a refill of 3 litres of diesel and the remainder as ATF. Both are high detergent and over the next month they should clean the height correctors and any other contaminated/sluggish slide valves. When the ride and operation returns to normal, empty, clean and refill the LHM container with LHM.
I will keep you posted on how this turns out. If there is no word from me, have a look if I am posting under the Peugeot or Renault forums.
John
John
