I don't think it's carved, resin more like it. The table is carves circa 1995 when I had better eyesight and more energy.
Bah its easy, I'm a 5 minute internet expert didn't you know.You are a clever Dick
Excellent work, young fella!I've been tinkering with home sand casting for 2 or 3 years now and seem to be getting the hang of at last, my failure rate has gone from about 95% down to 5% or so. Sand casting can be so much fun I am surprised everyone else isn't doing it too. Sand casting can be time consuming though because a pattern has to be made to reflect the finished article and depending on the shape of the item the sand mould itself might need to be made in several pieces to get around undercuts and odd corners etc. Hollow parts will need a core box of some fashion to make the internal sand mould and for a one-off item it can be difficult to justify the time it takes to make a complete cast part.
I have a solution, if you have a close look at the pattern in the first image below you will see that it is made from a coffee cup, a piece of cardboard tube, some cork and a couple of sand biscuits all glued and taped together to form the shape of the required part but is also hollow so is used as a core box at the same time. Making a piecemeal pattern like this is really fast but there will be a bit more fettling after the casting is done to remove marks and make it look pretty. I did say it was fun..
View attachment 207377 View attachment 207378 View attachment 207379 View attachment 207380 View attachment 207381View attachment 207382View attachment 207383
Why thank you, I do wot I can.Excellent work, young fella!
Thanks PeterT. I have been under pressure by a few to get setup for 3D printing but I can bang out a proper timber pattern quicker than a printer could do it but lately I have been making disposable patterns for one offs.Maybe you should invest in a 3D printer? They make pattern making easy.
Well then I'm in good company, you go alright yourself...You never cease to amaze me with your talents! Well done my friend.
Seeing as Graham is a master craftsman with wood maybe a CNC router would be the way to go.Thanks PeterT. I have been under pressure by a few to get setup for 3D printing but I can bang out a proper timber pattern quicker than a printer could do it but lately I have been making disposable patterns for one offs.
Maybe, a CNC router is $20K+. A 3D printer is $1K or less. Also, a router can only make half a pattern, whereas the 3D printer will make the complete the part.Seeing as Graham is a master craftsman with wood maybe a CNC router would be the way to go.
At present I work in a foundry that makes ferrous castings, the parts that make up the pattern are made on the CNC router.
