Re welders, is something like this reasonable to aim for?
https://sydneytools.com.au/product/unim ... ick-welder
Decided ~7-800 is kinda the silly money I'm happy to play with (Oh, and I appreciate there is another ~$600 in saftey gear and a bottle of gas) and want a welder that will end up with me playing with TIG eventually. Needs to be a 10amp (still renting) and something that does Stick / Mig / Tig makes sense?
Google reading tells me a ~180w machine usually has enough control / flexibility for the thinner sheet metal I'll end up playing with? I'm not exactly sure why this is the case but assuming simply better chineseium internals that can handle voltage control better? Or perhaps it's just that the cheap TIG machines are junk?
For the project list;
- rear arches (might just epoxy / fiberglass them)
- various rust repairs
- making a spring compressor tool
- making a bracket to hold the brake master cylinder still (moves like a trampoline against thin firewall)
- make some suspension braces between front / rear towers / copy the racing spanish reno nerds
- make some adjustable control arms / adjustable tyre rod / trailing arms.
- exhaust manifold
- inlet manifold (most likely steel, and tiny, like ~40mm inlet runners for motorbike style throttle body to valve distances
- seem weld the POS (because idiot)
Point being, there is heaps to learn and practise on and what better way to do it then sending my electricity bill through the roof!
