The nearest this gets to be being automotive related is that it is installed in my caravan/camper.
My Coromal camper/fold-down caravan has a very neat Heater/Air Conditioner installed under a bed with 3 x 65mm ducts to 3 outlets in the van.
It's a nice unit, in my opinion, brand is Truma Climaster, this is the installation & owner's manual if you are interested:
This van is about 16 years old but has had very little use, and been in storage for about 10 years. (Might I add that buying this van is the probably the worst financial decision I have ever made, not because it's a bad unit, but because we just never got the opportunities for extended holidays and various family commitments. I bet I'm not the only person to ever say that about a caravan purchase!). But I am now restoring it to a good saleable condition, and finding that most of the built in units are working OK which is a bonus.
OK, my query is with the reverse cycle unit as above. It is only designed to work when connected to 240v AC, not 12v or gas. Now when I first checked it last week, I concluded that the fan was working (blowing good air) but the compressor/gas system had failed/leaked, because it was not cooling - I had a thermometer at an outlet as one does in a motor vehicle, expecting it to drop to under 5°C, but nothing after 15 minutes or so. Same with switch set to Heating - just cool air.
THEN I READ THE OWNERS MANUAL!! (What?, I hear you say )
Interesting - (a) the air conditioner will not operate below 20°C, and (b) the heater will not operate below 4°C (which is when you would really need it - but fortunately in our climate - not often).
As it was probably about 15°C when I was testing the air cond - I may have concluded incorrectly.
So I tried the heater again and after about 10 minutes I did note a slight warmish air at the outlets, so I left the van closed up for an hour with the heater running - and voila - 26°C in van with 18°C ambient - that took me by surprise - so the heater is working fine, it's just a small unit (1.9kw heating) and took a while to heat up the room.
I finally get to the question of the day, for the knowledgeable among you.
It's a reverse cycle unit, so if the heater system works, am I to presume that the air cond should also work when the ambient is in a range that it will operate (ie, over 20°C)? As far as I can see, the same compressor works as a heat pump or an air cooler, so I am hoping that it will.
Hoping for a 22/23° run over the next few days so I will give it a go, but it might be a while before we get an actual "hot"day.
Obviously if the air conditioner/heater works, and I have already confirmed the 3-way fridge works well at least on 240vAC, then it bodes well for a good price when I sell the van hopefully in the next few months, and less expensive repairs.
And hey, I don't need any comments on the fact that a camper has an aircondioner!
Cheers.
Cheers.
