hello
haynes says to completely slacken each bolt then retighten.
the "ajusa" cylinder head gasket instructions say to slacken 90 degrees and retighten.
what's your experience?
you have to loosen each bolt completely?
I would've though that angle tightening would be more relevant to TTY bolts
Roland- what did you do regarding the liner seals? Did you compress them or measured the protrusion?
did you use hylomar?
Well, I guess the reality of that puts to rest the old debate about angle tightening vs torquing.
All the same, I would have thought that it would not leak at 50 lbs. Except that things did not get initially compressed and seat properly....
. . . Could it have failed because I waited 2 months from installing the head until I started it? . . .
. . . Roland- what kind of sealer did you use on the seals? . . .
