The current Astra has a 5 stud pattern??? malletHaakon:
Better off to use something like a current Astra (which will be fairly new from a Holden wrecker) caliper and the Astra disc (right stud pattern and for a FWD)
Haakon:
R25 V6's have 5 stud wheels...Originally posted by mistareno:
I was thinking rear disks of a E30 BMW. I want to be able to get service type parts easily.
Good idea (right stud pattern, but BMW use a separate drum for the handbrake which may complicate matters, plus its a rear drive setup, so mounting on the Fuego rear hub may be tricky. Plus its not Renault. Better off to use something like a current Astra (which will be fairly new from a Holden wrecker) caliper and the Astra disc (right stud pattern and for a FWD) or some R25 V6 discs that Ken @ Carrevelle has new.
How much and where did you get them? are you doing the work yourself?mistareno:
I am currently fitting SPAX adjustable coil-overs to the front and then I will upgrade the brakes. (more likely 25 front disks than laguna). Only when the thing stops and steers how I like it too will it come of the road for some "tinkering" in the engine department.
