That has always been my undestanding also. Bear in mind that I was thinking of shaving a bit off the head to bump up the compression ratio (not just a resurface for gasket mating) whilst also fitting a warmer camshaft (the engine is otherwise very healthy).Haakon:
In fact, dont replace a head gasket WITHOUT having it done, as it ensures a good seal. The fraction of a mm that is taken off is irrelavent to the belt tensioner.
They say it ONLY for that motor. Every other engine ever fitted in a Fuego (847, 843 etc) has a minimum deck height except the 2.0L OHC motor. Must be a reason, i'm just buggered if i know what it is. I've worked on squillions of cars and have very rarely seen this come up...Haakon:
I suspect Renault just say that as an arse covering statement.
FWIW, the same statement is given on the PRV V6 motor in my documentation.mistareno:
I was thinking rear disks of a E30 BMW. I want to be able to get service type parts easily.Haakon:
I only mentioned Laguna brakes as you get a balanced all disc system with ABS. But 25 fronts and (if you can get them) 25/21/Fuego turbo rear discs will do very nicely.
mistareno:
Good idea (right stud pattern, but BMW use a separate drum for the handbrake which may complicate matters, plus its a rear drive setup, so mounting on the Fuego rear hub may be tricky. Plus its not Renault. Better off to use something like a current Astra (which will be fairly new from a Holden wrecker) caliper and the Astra disc (right stud pattern and for a FWD) or some R25 V6 discs that Ken @ Carrevelle has new.
(what, you dont think the Fuego wiring is bad enough?)
Nah, the more complicated and harder to fix, the better D
Does anyone know what kind of power a NG3 box will handle reliably? Bear in mind that I use the box properly
I did silly driving a lot in My Fuego's, and they were fine. Ask the R21 Turbo boys in the UK what Renault did to the Turbo box to make it stronger.
QB]
