Following this thread by Decca and referring to a couple of YouTube videos, today I took apart the Com 2000 unit in my 2003 Peugeot 406 to fix the dreaded floppy indicator stalk.
I wasn't comfortable removing the steering wheel with the airbag, so the whole operation took place at my mechanic's premises. After he removed the wheel, I got to work and had little difficulty pulling apart the unit. I broke only 1 plastic tab due to aging plastics. I replaced the plastic rod with the spring inside the base with one of these items, purchased from eBay. Mine was so badly worn that you couldn't tell that it was supposed to have a rounded head on it.
Reassembly was not as easy as disassembling the unit. Both black tabs on the back of the unit which control the self-cancelling blinkers broke. I can't see that they'll have much of a negative impact other than the blinkers won't self-cancel. Please correct me if I'm wrong. But here's where the 'fun' began.
Once everything was put back together, (my mechanic did almost all of the work as it was getting late in the day), we reconnected the battery and turned on the ignition.
After that, at various stages, the complete Com 2000 unit was removed from the car yet the wipers and washers would continue on their merry way. Yes, even without the wiper stalk being connected inside the car. Then, again with the Com 2000 unit out of the car, the headlights would turn on. Sometimes it would be dipped beam only whilst at other times it would be dipped and main, or maybe just the main beam! There was no recognisable pattern. The only constant thing was the wipers would operate all of the time whenever the battery was connected.
So, please help me understand what's gone wrong. (Yes, it doesn't work as intended!) But why? And much more importantly, how do I fix it?
Thanks for any help!
Andrew
- The wipers started of their own volition.
- The windscreen washers sprayed continuously.
- The indicators didn't work at all.
- The headlights didn't work (neither main nor dipped beam).
Andrew
