I knew you could meet the challenge one way or another if you really wanted to. Actually they look very much like pre WW 2 Ford wheels.
By gove, is that a fregate in the back ground...?
Interestingly, it looks more like an MGA than her usual Floride/caravelle (I can never tell the two apart!)
Well it's all up to you. You know you've got the capability. Although have you tried making wire wheels yet? There is plenty of info. A car up near Gatton. You will need big spanners. Some nuts are 36mm!! Well at least one is. You are a fast worker. Done in 18 months. The car club in France has some spares. Many, like universals etc, are standard sizes. The rubber dough nuts on the drive shafts can be rebuilt, they were standard off the shelf in the day may still be used in industrial equipment. Go for it!!!
A coupla lads fixing one up...
Here's a pleasant way to spend 14:05 minutes, if you don't like the music just turn it off...enjoy
And the dulcet tones of Mario Hacquard
It is very nice. Great for a Fregate fan, which I am. Unfortunately my internet is so slow that it takes me 12 minutes to watch the less than 5 minute video. Still I persevered just because it was about the Fregate.
On the other video, which I don't want to sit through again because of the speed thing, I thought it appeared that some welding was actually bronze brazing. Do you agree. If so how did he do it without buckling the metal? And would it be strong enough? Also would it be legal? Back in the day it was legal to use brazing to build race car chassis providing a certain type of rod was used. Any one have any knowledge of that and what it was, and is it still available and legal? It appears as if some of the assembly of the Floride Caravelle was done using what appears to be bronze brazing.
Hi Sunroof,
Regarding the welding. In times past I used brazing or bronze welding a lot. I was into maintainance and it was applicable to just about every repair. Sheetmetal, broken castings, cracked frames, building up worn shafts, making exhausts etc etc. It's a manualy applied method which has gone out of favour because its slow and hot but still just as effective as it was before. It was used a lot, all bike frames were brazed together up till perhaps 20 years ago. I raced Karts which were brazed frames. The bronze flows into and around the joint so the stress is spread more than a thin line of weld. Strength is excellent.
I am sure you can find plenty of information on the web and certainly in some of the older welding books. It is done by visual control so is quite satisfying to do as you can see how it is going and adjust as needed. Just a manual skill which is learnt by a bit of practice. Getting the flame right is the key. CIG had a range of rods and fluxes to cover all types required, not sure if they have now.:nownow:
jaahn
Hi David and all
While brazing is not " current industry practice", it certainly was in times past. I fail to see why it would not be "legal" as it is a recognised professional welding technique. Certainly a lot of older cars had bits held together like that and there was no reason to doubt it. Spot welding just took over the body joining as it was quicker. I suppose insurance companies would not pay for it but that's because they want fast cheap jobs.:joker:
Brazing continued as a repair method as Dave said for quite a while, until spot welders and then Mig became available to the general trade. Faster and perhaps less skill required for average jobs. However in general industry brazing was well used for a lot longer, as it is versatile and you can do a lot with an oxy set and also take it almost anywhere.
Those coat hanger welding rods, of course were steel, not bronze. We all used them ! They often gave sh*t welds if there was a coating on the wire :crazy: Brazing is easier than oxy welding on thin rusty parts because you do not actually have to melt the metal so it does not "disappear" as you weld and blow holes. That's the theory anyway:joker:
jaahn
