The existing 1647 842/841 engine has many road miles on it plus a few racing miles so I am building a fresh engine.
I previously started a thread when considering a 1796 cc engine. During the time since that thread was hijacked in October last year, a few parts have arrived despite COVID related supply and shipping delays. This new thread picks up the progress of the new engine build.
Salv Sacco helped out with a set of 80 mm liners he had on the shelf and some nice new forged pistons. I plan on running about 10.5 - 10.8 :1 CR so that I don’t have to chase fuel availability problems.
A cam is at Clive Cams and will be ground in the new year. We are still working on a suitable grind profile. Always a compromise for road and track. I currently run an old, mild Cosworth/Waggot grind. Can’t remember the specs.
The block needs a lot of work to repair some corrosion around the seal area at the bottom of the liners to make sure there is reliability. The block corrosion is part of the reason I have gone for 1700 not 1796.
A lot of work is being done on the 807 head to change the water flow to the opposite end. The head will need a lot more work to fit the pistons and big valves.
I will post some pics of the progress of head mods so the water pump inlet is at the rear of the car, not under the back window.
The new H beam rods arrived, I have 3 cranks to choose from, I will select the best one after crack testing and a polish of the journals to work out bearing size.
Still waiting on Alpine 110 engine parts from Jean-Yves in Belgium. I believe he has a problem getting some bits from France.
