Hello all.
I am at the brink of giving up in despair with my manual 308 (2015 non GTi). The problem started when it died with all lights flashing on the dashboard + limp mode during a long-ish drive on the motorway back in Jan 2021. I towed it to a nearest mechanic who replaced the spark plugs and got me going. But the car wasn't as smooth. I took it to the authorised service centre who identified the spark plugs being wrong and replaced them again. The car still wasn't as smooth - I mean engine vibrated at high speeds. I was told it will take some time to "learn". A few months later I took it to another authorised service centre who advised me that the problem is due to carbon buildup and will need a walnut blasting process that costs upwards of 2000 AUD. I took another opinion from the first service centre (who had replaced the spark plugs) and they too told me the same + VVT solenoid servicing (or replacement) with a total estimate of 3000+ AUD.
Fault code (according to the service centre) is:
Car has around 60K on the odo (30K under my ownership) and my use is 80% motorway, 20% suburban.
A few more opinions I've received from other service centres were:
- vibration is due to the engine mount.
- vibration is due to the transmission mount.
- vibration is due to the drive shaft/ cv-axle.
I know of carbon buildup problems in direct injection engines but that is easily solved with carby cleaners. This car however seems to have been built in a way that is next to impossible to carry out such servicing at home - I couldn't find the intake valve to spray in the cleaner, seems it sits at the back of the engine underneath the windshield.
Fuel additive seems to have helped to some extent. May be I should repeat this additive a few more times? This also reminds me that I must admit I've used the wrong fuel (E10) during first 4 to 5 months of my ownership but that was back in early 2019. I've been using premium 95 since.
Is it safe to plug in my own generic OBD2 scanner to try and figure out myself?
Can someone please also suggest me a service centre who can help me with the throttle body clean without having to go through the walnut blast process- i.e. using Liqui Moly, CRC, etc.? The authorised service centre flatly refused to do this and are pushing me for the expensive walnut blasting process instead.
TIA.
- Kris.
PE0091 = super knock and intake VVT solenoid.
Vehicle will require carbon clean $2500 supplied and fitted.
VVT solenoid for manifold $500 supplied and fitted.
TIA.
- Kris.
