PeterT,
Thanks for the info
What i was trying to say was that the former heat treatment will be lost when the material is added by tig welding the aluminium head.
Even if the whole head is stripped and everything is replaced the head will loose most of the factory heat treatment.
I talked to some WIA welding engineers in the states (These guys r the best they get paid well over 5-7000 a month dollars for there knowledge)
I explained to them i was training in the best aviation facility in Australia and that i am interested in welding aluminium heads.
They told me it depends on how much welding or modifying is to be done.
If resurfacing is done to improve the head
The head must be normalised after welding
And then further heatreated after that to factory specs and then (The machining will follow that)
I did know i needed an oven and such so i put it on hold.
They elaberated even more but i cut it short
They stated the head will work harden by regular driving (But by the time it does you valve seats and guides will shift)
They let me know that if you don't want a scrap head you will have to go through the above process
hope some of this helps.
Murat
Thanks for the info
Murat
