No lock pin again Now I need two of the damn things ... the key pin that is.And see if the lock PIN code comes with the car. Be prepared.
thanks, that is a little better. I've identified the switched power, power and earth ..... the speaker wires are labelled in the diagram. So we are set .... If I put in a reverse camera I'll grab the feed from the reverse light bulbs as its easier than searching the dash (the pedal switch should be switching the earth, not 12volts ... so no point looking down there).This may explain the connections a little better Shane.
