It'll be a C3 manual. And the sound is almost certainly the chain tensioner.
Oh gees, he needs to stop running the motor if its from behind the timing chain cover...... I hope its not an interference motor!It'll be a C3 manual. And the sound is almost certainly the chain tensioner.
It certainly is. Chain unlikely to break though.Not interference!
It's been many years since I did a 504 timing chain, so assuming that the 404 has the same type of tensioner, don't you have to be careful that you don't unlock it when it is out of the car ? Or take it off while unlocked ? I have a vague memory that once it's gone SPROING, then it cannot be reloaded and put back in the car. Or am I thinking of some other type of engine ?Personally, and I know it's a bit of mucking around, I'd be inclined to take off the timing cover, remove the tensioner and give it a good clean out, checking the oil feed gallery behind said tensioner at the same time. Giving the engine a good run may help things as well.
There is a rotatable device with a screwdriver slot, in a hole on the side of the tensioner to keep the piston in the tensioner. After fitting rotate the slot to release the spring again.Sounds like I'll do the following 1) not run the engine again until the timing chain tensioner is changed and tensioner oil filter cleaned, 2) get some help from someone who's done this before.
I found this link (in French but easily translated) which explains the process is quite some detail:
Calage de la distribution - Technique Peugeot 404
. Le calage de la distribution est la synchronisation entre toutes les pièces de ce que j'appelle l'attelage mobile notamment entre les soupapes et les pistons C'est une opérationfrancis404technique.free.fr
In this link the mechanic says:
'remove the chain tensioner after taking care to release its shoe from the action of its spring...block its system to prevent the tensioner from exploding in the garage when it is removed'.
There is a different method for doing this for Reynold and Sedis type tensioners (explained)
ThanksThere is a rotatable device with a screwdriver slot, in a hole on the side of the tensioner to keep the piston in the tensioner. After fitting rotate the slot to release the spring again.
Yes. Good newsSure glad it was not the timing chain, that would have been a pain.
