I have taken the 403 water pump off as the bearing is make noise .
it is a late model water pump with circlip in front of the bearing.also has grease nipple..strange?
i understand the shaft has to come forward but than the impeller is at the back.
how to pull the impeller out?is it a press on?.it is a thick impeller almost 3mmm thickness
i have another water pump that the impeller is about 1mm +
what my chances of pulling it without damage.is there any peugeot style trick to pull it
thanks ron
thanks ron
