ok thanks i also haven't time the pump i didn't move from cradle when i took of 405Maybe, they crack at a lower pressure ending up with too much fuel. Check a 405 SRDT or Bosch 306 for these. You have the fuel lines obviously.
i did smell fumes i didn't really see any fumes thanksIs there any smoke out the exhaust while cranking? If so, what colour?
yes i guess so thanks but if not really needed might be a waste of time and money ,thanksPump will need to timed for the thing to inject correctly, if the 405 is still available go get the injectors? Smelling fuel means its pumping through the injected mix. Should be whitish mist at exhaust.
ok thank you i try go back see if they are on car still or even if the car is still there ,thxMostly agree, but you will save on fuel and get better atomisation which is better efficiency.
yes thanks i have taken the pipes thanks i just want to start the carGrab the injector pipes for the Bosch also. You need to bend the Lucas ones a bit too far to be safe when fitting the Bosch pump.
thanks champNot much point trying to start it until it is timed properly. A diesel won't start from cold unless the timing is pretty much bang on.
Once that's sorted, make sure it is completely bled of air in the delivery pipes, and that your glow plugs are working properly. Then start it.
