Just had a service done on my 2007 207cc 1.6 vti and my mechanic says it has the following issues
vacuum pump oil leak
oil filter housing leak
broken rear engine mount
worn lobes on camshaft causing tapping noise
I also had him do a compression test for any coolant leaks as I smell it sometimes through aircon (no overheating, no white smoke , no coolant in oil, level ok, no wet patch on passenger floor) Couldn't find a leak but I think it's a small one in the heater core.
I also get a P0597 code with my OBDII scanner which a neighbour mechanic says is "a lazy thermostat"
It has lousy fuel economy (either 95/98) also.
So my question is what is the most urgent of the above list to get done. I know the heater core would be a big job as would have to remove dash.
I'm thinking the oil leaks are the most important. Can they be fixed with new gaskets/sealant or do I need to replace vacuum pump etc?
