Oil filter change interval
I write down every single detail related to any work I do on the car (mechanical, electrical, AC ...) if this is what your asking.
But if you mean an official maintenance schedule from Peugeot, the answer will be no, I only have he owners manual.
Regarding the 2nd part, your logic is encouraging & the vehicle is only driven on the highway for a minimum of 20 Kms per trip.
Here is mine for the RCZ:
Date Klms Service
20th Dec 2018 39,500 Oil change Castrol
Oil filter change
Nulon engine oil flush
SA459
Fit K&N air filter
Replace pollen filter
Replace spark plugs
Replace wiper blades
Fit THP emblems
29th Dec 2018 39,700 Fit entry door lights
4th Jan 2019 40,000 Install new battery
15th Jan 2019 40,600 Fit door latch covers
Clean leather
9th Feb 2019 41,400 Fit new gear nob and
boot
Rotate wheels
Clean brakes
15th Feb 2019 41,600 Fit left foot rest plate
4th May 2019 44,700 Oil change Castrol
SA459
27th May 2019 45,600 Replace coolant cap
28th Sept 2019 50,000 Oil change Castrol
Oil filter change
SA459
28th Nov 2019 52,900 Fit new Bridgestone
Potenza S001 tyres x4
Change transmission
fluid. Redline MT-90
29th Feb 2020 55,300 Oil change Castrol
17th Mar 2020 55,800 Replace pencil coils
24th May 2020 58,500 Repair pop-up display
Replace coolant cap
3rd July 2020 60,000 Oil change Castrol
Oil filter change
SA459
26th July 2020 60,600 Add Redline ST-1 fuel cleaner
18th Oct 2020 64,200 Replace coolant tank sensor
1st Nov 2020 65,000 Oil change Castrol
Replace spark plugs
(NGK ILZKBR7B8G)
Clean K&N filter
26th Dec 2020 68,000 Clean leather seats
28th Feb 2021 70,000 Oil change Castrol
Oil filter change
SA459
26th March 2021 71,000 Fit new coolant exhaust pipe.
Fit new water tank/thermostat.
Flush coolant/refill
Change brake/clutch fluid
5th May 2021 72,500 Add Redline ST-1 fuel cleaner
16th May 2021 73,000 Replace brake light switch
29th May 2021 73,800 Replace key fob batteries
10th July 2021 75,200 Oil change Castrol
24th July 2021 75,700 Replace pencil coils
Replace spark plugs
(NGK ILZKBR7B8G)
1st Aug 2021 76,000 Replace pop-up display
9th Aug 2021 76,300 Install new battery
25th Sept 2021 77,700 Fit tyre valve caps
9th Oct 2021 78,200 Replace rear left tail/stop bulb 21/5w
9th Dec 2021 80,500 Oil change Castrol
Oil filter change
SA459
Engine oil flush
5th Feb 2022 82,400 Fit Potenza Sport tyres (x2) front
Cut & Wax
20th Mar 2022 83,900 Clean leather seats
1st April 2022 84,000 Clean rear left ABS sensor and ring
Re calibrate the
steering wheel sensor
6th April 2022 84,200 Wheel alignment
6th June 2022 84,700 Fit Bilstein shocks
Fit new strut tops
Fit new brake rotors
Fit new brake pads
Bleed brake fluid
New rear wheel
New rear tyre
Replace torsion beam
Replace stud axel
(rear left)
Replace inside hub
Assembly (rear left)
Wheel alignment
Oil change Castrol
Bleed clutch fluid
Fit lightweight
flywheel and clutch
Redline MT-90
transmission fluid
R & L driveshaft seals
New timing chain kit
Kilometer
Item
90,000Replace oil and filter. SA459. Oil flush.
90,000Clean K&N filter
90,000Replace pollen filter
100,000Replace spark plugs
Month
Item
Sept 2023Replace engine coolant
June 2024Replace brake fluid
4000kms of highway work in a year? In a simple tough old 504 engine? On modern full synthetic? Leave it alone ;) Change after another 4000kms/12 months.
With the caveat its parked somewhere dry and run fairly regularly. The only contamination of relevance here is condensation I'd suggest.
Not pug related specifically but should be the standard, get the oil tested! I did this on my Landcruiser, spec said city driving is arduous, 5K intervals, Test oil showed it very good still at 10K intervals. If you cannot measure it how can you manage it? I will be doing this on my rebuilt Mi16 that's for sure! Does not cost much, approx 30 dollars. Cheap insurance.
Hi.
Well done for using an empirical test to determine engine oil change interval.
This mini case study supports what I have been suggesting for a while on this forum. That many litres of good oil are needlessly replaced and tipped into the waste oil drum.
A dealer or any service centre is never going to not recommend changing oils. It’s revenue for them and what their business is based on.
As to arduous service for city driving its a bit ambiguous. It really depends if the engine is able to reach operating temperature and remain there for say 15 minutes or so. The average urban commute along arterial roads and freeways for 20+ minutes achieves this. Therefore it’s not really arduous service.
That is why many vehicles use an algorithm to determine service intervals based on a range of inputs specific to how that vehicle is used. This is a good feature that reduces running expenses for the owner without compromise for the vehicle performance and durability.
Cheers.
Here's my Belingo one.😉
Feb 2022 bought car (back again).
Feb 2022. Changed oil @ 149,000kms no filter as the clowns at Repco gave me the wrong one and I wasn't driving back to town again.
Used Castrol GTX3 that I bought on sale last year for $9.95 for 5L. I have shelves full of it.😁
Feb 2022 fueled up x 2 @ $60
March 2022 fueled up x 2 @ $70
April 2022 fueled up x 2 @ $80🥺
May 2022 fueled up x 2 @ $100😥
June 2022 fueled up x 2 @ $110😢
July 2022 fuel up?🤷‍♂️😭😭
Yeah, but the car has done 4,000 in one year?
Very little condensation will come from being parked, even outside. Blow-by past the piston rings brings lots of water vapour into the crankcase. When the engine's cold, this will condense and settle into the sump. When the engine's hot, it will stay as vapour and be drawn out through the breather. So 4,000 km made up of 200 20km trips, no problem. 4,000 km made up of 4000 1km trips, yes problem.
Have fun,
Rob.
Arduous for a diesel landcruiser, not designed for short stop start traffic!
I hate oil change wars . . . I'm out of here . . .
I gets driven every 1-2 weeks for 40-50 Kms on the highway. It doesn't sleep for months.
This is what the oil looks like:
Hi.
The oil looks pretty normal to me.
I'm a bit surprised that when I Google Cairo climate that it gets down to 11C in Dec, and 10C in Jan, I thought it might be much warmer. So your 5W-40 multigrade oil will be working well.
Cheers.
I keep mine written in an agenda to avoid crashes or losses :D
Date Klms Service
Oil filter change
MonthItem
My fueling data goes into an excel sheet which calculates the consumption in 2 different units so that I always keep an eye for any anomalies.
So far it's doing pretty good thank God.
I think I'll stick to that viscosity & spec as long as it's not being consumed.
And yes it gets a little cold at night in Dec/Jan but nothing unbearable :)
Starting next oil change, I'll probably switch to Wolf Vital Tec 5w 40, which my 308 found a bit heavy on cold starts in the winter (could hear the timing chain rattle which went away immediately when I switched back to Mobil 0w-40)
Hi.
Cheers.
That's what I call getting the oil up to operating temp :cool:
Have fun,
Rob.
5w-40 is way to thin for the OLD STYLE xn1 engine, 15w-40 is the thinnest I'd go, but had good experience with 20w-50 (HPR30 PENRITE) over the years, dad and my grandfather ran 20w 50 in 504, 505 xn1 engines since they were brand new at the dealer. Dad worked at East Ivanhoe motors.
5w40 is ideally good for over head cam late model engines.
Every 10,000km is perfect for it, if your racing or thrashing it I'd change every 5k, but our race cars get changed every 3events. But there's also no harm in over changing oil if you've got the money too,
But 4k between services is abit much unless cheap crap oil.
Cheers BP
Yes, HPR 30 is the go. It was on special for $44 at Autobarn this week too.
