Hi everyone, I'm a new member but a long-time lurker
So this is a DW10BTED4 138 2.0 HDi engine, build date 17th May 2006.
I've been given a non-running 307 HDI 2.0 with a siemens ECU, I've got the feeling a few people have tried to fix it as has a few new sensors and the BSM was not clipped down properly. Scanning with PP2000 it has a number of faults, but the one I really want to start with it reads an incorrect battery voltage, by around 2.5 volts, even with a charger on the battery it will read a low voltage of about 12.0 volts. So the car goes into economy mode and PP2000 will not communicate with the BSI. Normally with a battery voltage of 12.8 volts, PP2000 will read around 10 volts. I can't get any live data with the engine cranking, which is typical of many of the pugs I've checked in the past when the car is in economy mode, The immobiliser data says it working correctly and is not locked.
I've also noticed that the fuse (f11) on the BSM reads the same voltage as PP2000 and also the PP1 connector has 2 large wires to the BSM one of the wires has the same voltage (T2)
I've removed the BSI, and BSM checked for dry joints and checked all plugs, grounds and fuses for corrosion. There is a ground point below the left front door under the carpet, which is connected to the BSI and a number of other systems heater, AC etc. I found one of the crimp on connectors with 2 heavy wires quite green and corroded so I've replaced the connector with a couple of ring terminals. But the fault still remains. Im starting to run out of ideas, thanks, everyone.
Here is all the data I could find on PP2000
