Hi Guys,
I have posted stuff before about hotting up an r17r18 motor. Generally speaking, the replies have come back with the following suggestions;
compression ratio increase
twin sidraughts
extractors
camshaft grind
balance and blueprint (if money allows)
bit of headwork if possible
And if course generally replace worn out bits,re-ring, bearings etc
My question is this- how easy or wise is it to increase the capacity on the (843) 1647cc motor? Being a wet-sleeve motor, and if you are going to the cost of replacing the pistons, why not get bigger ones if std replacements are hard to come by?
How big can you go before the liners get too thin, reliability/integrity is compromised? Is this a logical progression for more grunt- the only other way I can think of stroking the motor- is with a different (very expensive) crankshaft isn't it?
I was thinking that if I could get an increase in capacity to close to 1800cc, with the twin sidedraughts that I already have, and extractors, cam grind and balance everything that it would make a good, strong motor. I have finally had the go ahead to spend some money on it(from the missus! head_ban so am trying to suss out sources for parts etc- ie so if I am going to be hunting out forged pistons and could get a 'free' increase in capacity it'd be silly not to take it...
Another thing, this motor the camshaft had specs of (I think) 72, 32. Will this be a hot enough cam for what I am trying to do? The aim is around 140 odd hp, and the car is used relatively infrequently...
My apolgies if some of this seems like rehashing earlier posts- it's just that I don't think I got a definitive answer on the capacity issue.. cheers!
Cheers Ben
twin sidraughts
extractors
camshaft grind
Cheers Ben
