I bought an endoscope off EPAY a few weeks ago. Perfect for cylinder inspection @ about $50. Better than pulling parts unnecessarily.
The leak down test would prove where compression is leaking from, like from inlet or exhaust valve, rings or the head gasket.Hi Col - my mechanic says as it isn’t blowing smoke he thinks it’s the valve, not piston. No. 1 cyl zero compression, No.2 and others 155.
I wasn't sure what engines had that style of rocker, just read on here somewhere that it was a Peugeot engine.The disposable rockers are on the HDI diesels.
A leakdown valve test involves pressurising the cylinder and listening for the leak. Is this the 2.0 L EW10J engine with the moulded manifold? If it is a valve it's head off time.
