Daniel
Not that I know much about carbies but just looked up the Haynes Weber Manual
and the following specs apply to
32 DIR fitted to the R1229/1329 5 Gordini R122B also
Stage (venturi) 1 2 1 2 1 2
Venturi diameter 23 24 26 26 23 24
idle jet 42 50 55 50 47
Main jet 117 150 130 145 117 135
Air correction jet 190 185 155 145 175 190
Emulsion tube F20 F20 F50 F50 F50 F24
Accellarator pump jet 50 60 60
Float level 1 (mm) 7 7 7
Float level two - - -
Float stroke (mm) 8 8 8
Needle valve size (mm) 1.75 1.75 1.75
Choke fast idle gap (mm) 1.1 1.0 1.0
Choke pull down (mm) 8.0 8.0 6.0
De-choke (mm) - - -
Defuming/vent valve (mm) - - -
Don't know if this helps you and I hope the spacing doesn't alter with posting
Regards ken (Just checked and the spacings are all over the place!!!
De-choke (mm) - - -
