Following this discussion with great interest, since I bought a new alternator with integrated regulator from Der Franzose for my DS23ie BVH (LHD) before reading this - that'll teach meAt least one solution would be to use the old regulator as a binding post. Disconnect the BOB wire from the regulator and insulate it for safety. Tie the L wire and the former EXC wire together using the EXE terminal on the vestigial regulator as the binding post. (The EXE terminal is not connected to anything once the BOB wire is disconnected). Then, connect the EXC wire (which has a spade terminal at the alternator end) to the "lamp" post on the new alternator. Basically, you are commandeering the EXE wire to extend the L wire to the alternator. No changes to the wiring loom.
John
