Yes but I made a "should have known better mistake". Or "it is easy in hindsight". When I tried to unlock the Fugeo with the remote it didn't work so I tried the key on the right hand door didn't work. Then the left and it worked. So decided that the right hand electric lock wasn't working. Took 3 hours to get it out. But found nothing wrong mechanically. So checked the fuses, fine but no battery at the lock. That is when I thought of the inertia switch. A 7 MPH bump and the doors unlock and there is no battery supply. The inertia switch has a small slide reset switch. Reset it and all worked perfectly. Spent another 2 hours getting it all back together again. Still don't know why the right hand door didn't unlock mechanically like the left did. Should have realised that the key was both electric and mechanical so if you had a flat battery you could get to the inside for the bonnet release catch. More importantly why didn't the inertia switch unlock the doors? Rob
