Odd, never heard of a xsara having an XU past 2002?Not here for the Xsara though, the other Coupe was the VTR with 1600. As I said my car is 2005 and has the XU10.
EW is mounted at 15º, XU at 30º. The TDC sensor is thus in a completely different position. Shouldn't be too hard to nut out.Should be possible if not straight forward.
Xsara gearbox is the same as the 206gti (BE4). But The donor car I've got has its original gearbox anywayYou need a Peugeot 206GTi gearbox.
not possible for a 2005 to have an XUI'll double check and take a photo of the build plate.
Should of made myself a bit clearer. I currently own a xsara VTS with an ew10j4. I have a C4 VTS as a donor with all its parts. The C4 VTS gearbox is a BE4 like the xsara. Xsara VTS dont come with an auto gearboxYou should also find an EW equipped Xsara for the engine mounts and exhaust etc.
There will be a lot of things different.
As someone who has done a big conversion like this, my advice is - don’t.
Life is short, it will suck a lot of time and the XU engine is still a great lump and more than adequate for the old Xsara.
I forgot to check when I was there, will have to wait 2 weeks for the answer now!not possible for a 2005 to have an XU
Yes, but your Xsara be4 gearbox has the wrong bellhousing.Xsara gearbox is the same as the 206gti (BE4). But The donor car I've got has its original gearbox anyway
ah well too late now lol. Guess Ill figure it outYes, but your Xsara be4 gearbox has the wrong bellhousing.
And your C4 won’t have the mounts and wiring and exhaust you’ll need.
