From the Froggy Chat Memories thread, for those that don't remember how a slide rule worked, here is some very basic explanation.
Aristo Studio slide rule 1966 vintage. They were made with various special features - this model was for Engineering students, note log scales top & bottom, kW/HP conversion. Scales C & D are base value "x", scales A & B are "x squared" (note RH end of scale), scale K is "x cubed", just align the main cursor (on sliding part) and get direct readings. You insert decimal value as required, eg, 3.5/35.0/350.0 all the same on slide rule.
Slide rule set to multiply by 2.0. Scale B = 2 is aligned to Scale A = 1. Everything on scale B is now scale A value x 2.
Example on sliding cursor (kW line) is 3.35 x 2 = 6.70. With practice, 3 decimal places is pretty accurate.
Explanation: The scales are logarithmic, you are adding 2 logarithmic values in this example.
Special feature of this engineering slide rule is kW to HP conversion.
Constant direct reading kW to HP on scales A & B. Note kW line and HP line on sliding cursor. This example set to 0.746 kW = 1.0 HP.
Interesting, as you slide the cursor block left/right the conversion kW/HP is constant. The distance between the 2 cursor lines multiplies by 1.34 so on the logarithmic A scale (or B scale) its a direct conversion.
Takes a bit of practice to use properly, but can handle complex calculations in the right hands. I've pretty well forgotten other than the basics.
Cheers.
Cheers.
