Hi
Our T7 308 2.0 HDi (230K kms) we have found occasionally goes over 90 on the temperature gauge (or once between 90 and red) and this occurs going up steep hills . When this occurs if we pull over sometimes the engine fans stays on (usually it doesn't). Coolant is just below max level there are no unusual sounds.
Whilst having a sway bar link replaced I got the dealership to check they said no related scan codes (I asked them to check) and visual inspection showed no issues and could not recreate the issue on a road test. I did wonder whether the fan issue was related to a faulty sensor but would that explain the temperature gauge going up?
Has anyone else had a similar temperature issues or have any suggestions what is going on or to daignose?
