Help Identifying a Diesel Engine
Halsey
New member
perth
My search skills on this forum are somewhat limited to say the least so please accept my apologies in advance if the information is already here. I have recently bought a four cylinder diesel engine to power a small wooden boat and I'm unsure as to exactly what i have bought. The bloke i bought it from said he thinks it is from a Xantia and he thinks it is 1.9 litre and it is turbo'd. I have found the following markings on the block but have been unable to tie them to what i have. PSA DHY, 10CUJW, 3013896. To add some confusion there appears to be a heart shaped marking immediately before and after the 3013896. Maybe that is the French sense of humour!!!
I am also hoping to find a schematic of the cooling system (it came with no radiator/cooling water hoses) that will help me plumb in a raw water heat exchanger correctly if someone can point me in that direction.
Many thanks
Halsey
Peugeot 405 XUD9TEY, 1905 cc, 66kW, 1987->
Does it look like this?
I think you'll find that the 'heart-shaped' marks are intended to designate the start and finish of the engine # - so that a miscreant can't easily alter the engine number by adding (or erasing) digits at each end.
Your engine may indeed have come from a Citroen Xantia, but it would have been a personal import in Australia (assuming you are actually from Perth, Western Australia, rather than Perth, Scotland). I think that Seasink is on the money - in Australia the 405 would be by far the most common source of such a motor, and 405 diesels were still sold new here in 1996.
