Hi all this problem cannot be fixed no matter what tune or new lifter you put in the engine,you just have to wait the one minute thirty seconds till coldstart phase is finished. I have had my 180 since 2006 and I too have the tune that magic sells and it is good for power and not leaning out at 7000rpm but the engine being the EW10J4S has an air pump that at start up actually puts O2 into the exhaust tract inside the cylinder head behind the exhaust valves, because of the amount of fuel an engine like this needs below 30 degrees celsius at cold start. This idea is so because when they bought this engine out, the emissions this engine put out was too much, so thus the added O2 makes levels read safe at the end of the exhaust and at the same time helps heat the catalytic converter up quicker. We had a lot of complaints during the warranty period for this ew10j4/j4s engines and some ew10j4 engines didn't come out with the air pump in early 100kw gti so these customers never experienced the fault.
The battery itself is an R & J Batteries MF55 branded AC Delco with no manufactured date stamped anywhere I can see. Good point though - I will get the battery tested.
Thanks for the informed responses..............
........Peugeot diagnostics didn't return a fault code & suggested an overnight stay at the garage... which never occurred. Its only been a problem for me since the onset of colder weather having not owned it long enough to enjoy all seasons!
