he's just copying my question from a couple of weeks back. They aren't metric threads. Have a quick read here:Does anyone know what thread is on a 6mm flare nut/ male?
British Standard Pipe isn't it? The larger diameters are Whitworth threads with a bit of taper I was told years ago. Lord knows what the small ones are. Then there's GAS. No doubt someone will enlighten me/us.BSP ?
Bob
The plumbing fittings that you bought from Reece will be BSP threads. Imperial brake fittings are UNF and are not compatible with BSP threads.More info, though now just as a matter of interest.
I have an old steel petrol tank (non french car).
It's outlet was just a piece of copper tube, but I wanted to install a bolt on fitting, so bought some 6mm copper tube from Reece Plumbing, and appropriate flare fittings. I called them 6mm, but yes I suppose they are correctly called 1/4" flare fittings.
As I had already brazed a larger nut onto the tank, I was considering tapping the nut so I could screw in one end of male-male 1/4" flare union. So was wondering what is the thread spec.
I thought it was 7/16th UNF. The thread pitch definitely matched a 7/16th UNF bold. But the flare nut wouldn't screw onto the bolt, and I don't have 7/16th UNF nut to check it on the flare male. Ok, thinks I, I will run a 7/16th UNF die over the thread, as it must simply be a different thread profile. That just buggered the thread.
In the end I brazed the male-make union in, and I still don't know what the thread is.
These are HVAC flare fittings, so they are not BSP.The plumbing fittings that you bought from Reece will be BSP threads. Imperial brake fittings are UNF and are not compatible with BSP threads.
It's done now, and the flare fittings are perfect for fuel lines, but I will look at the compression fittings for future reference. Plus I had the flare tools from when I replaced brake lines.For easy DIY at home you would be better off with compression fittings. I think you would be better off removing that fitting you brazed onto the outlet of the tank and clean in up the best you can and use compression fittings.
Noted and thanks, but I still don't know what the thread is on the flare fittings!Maybe if you explained exactly what you are trying to achieve the advice would be less general, there is plenty of experience here to help guide you.
