If I had no other chemicals to hand, I would probably try vinegar, which is a very weak acid. Spend $1 at Woolies or Coles. Vinegar saturated with salt is more effective as a bath, but probably not needed here.
Molasses acts as a chelating agent and draws the iron out of the corrosion products - i.e. the rust. This is why people can use a bath for their rusted old parts. It's kind to the good metal and acts slowly giving good control.
A faster acting (still a slow process) chelating agent is Deox-C from Bilt-Hamber UK and sold locally by the POR importers.
Bilt Hamber Car Wax, Polish & Clay Bars @PPCCO online shop
It is unfortunately expensive, but comes as either a powder to make a both or as a gel you can paint on and then wait patiently. The gel would be most effective here and leave you with clean bright metal.
A word of caution about chelating baths is that it will leave a black residue on your parts if you leave it there too long. This is most likely carbon remaining after the iron has been stripped away from the surface. It is more obvious with a product like Deox-C as it is faster.
