I failed at #3
. . . but to redeem myself I suspect this only applies to black spheres?
Actually it refers to all Dees.
ID braking system relies on main accumulator for front brake force.
If you fit a DS accumulator, the higher precharge pressure means that the usable volume (before the precharge expells all fluid reserve) under repeated braking is greatly diminished. For repeated brake application its volume, not high pressure that will save you.
There was an accident in the US where an ID owner ran out of brakes on the second push, and ran into the car in front at significant speed causing serious damage. It was only after deep questioning we found that he'd fitted a DS accumulator thinking that the higher precharge would be good, not bad.
It led to a significant improvement in the general understanding (of amateur mechanics) of how accumulators/spheres actually work in a complex system as found in the D cars.
