You're certainly not having much luck Don. I tried my printed bits at the weekend, the 3 cut nylon clips. They were stiffer than original, as you'd expect being new and unworn, but not unduly so.
Depending on the quality of the printer, male features tend to be slightly (technical term) oversize and female features slightly (technical term) undersize. In other words a pin is bigger, a hole is smaller.
Our desktop printer errs by 0.2mm in this regard so you can end up with 0.4mm clash radially or 0.8mm clash across the diameter if this makes sense.
The NZ printed trial parts I have here are 0.05 oversize/undersize which is acceptable and is why they work.
SF
All above is normal in therms of manufacturing considerations and once understood can be allowed for.
That fits with the part you sent up to me, it was a very tight fit into the headlight bracket and refused to accept the adjusting screw. You had explained that it wasn't the correct material, just a proof print so I didn't persist.
For Don, if he needed to use the printed parts he received a drill bit into the hole to open it up may have helped. Seems he is out of trouble though with used parts. The soft part could be be easily cut by hand using a rubber block, it essentially only holds the clip up against the bracket.
The important thing is we now have these parts modeled, with minor corrections they will exist for posterity. Thanks Printerman
