Looking under the bonnet of the cx I can only find a dipstick for the engine oil. Do these things have a dipstick for the auto and if they do where is it ?
Alan S said:Yep, TQF is the go. If I can get the old archives restored (ya listening Gerry??) I can post you a link on how to make a funnel device to use to refil the transmission via that dipstick hole.
BTW, you can see the dipstick just below the oil filter in the pic.
Alan S
Thanks guys , I found the dip stick now. Knowing where to look is a bonus. About that putting it into gear 12 times is a problem on account of it won't go into gear in the first place. Seems to be some oil on the dip stick anyway. I might try dropping the oil and put some castrol TQF. Note that this will be a long term project and I am only trying to get the car into the back yard and off the street for the momentDoubleChevron said:Now there's an interesting point ... Why on earth didn't I paint that dipstick bright orange when the motor was out ... Most certainly it'd make it easy to see when hidden down there :disappr:
Rob B said:Thanks guys , I found the dip stick now. Knowing where to look is a bonus. About that putting it into gear 12 times is a problem on account of it won't go into gear in the first place. Seems to be some oil on the dip stick anyway. I might try dropping the oil and put some castrol TQF. Note that this will be a long term project and I am only trying to get the car into the back yard and off the street for the moment
graham66 said:For topping up the c-matic I found it easier to just whip of the pipe to the oil cooler and squirt TQF through it - easy to reach, but downside it tended to overfill.
graham66 said:GS Alan - I have GSs. Hoses pretty easy to remove... Way better than undoing hard to reach filler plugs on gearbox casing.
