seeing as i'm a moderator i thought i'd start ea new topic so that i dont get told off by the big boss
I need a new clutch, the standard one wont cope so i have to look at aftermarket options.
An AP paddle clutch has been recommended, not too heavy and has good bite.
The 405 is mny daily driver and gets its fair share of city driving.
Any suggestions?
And back to the injectors, if i fit larger injectors and i'm easy on the throttle will the fuel consumption increase?
As in, if it's getting adequate fuelling at 3000rpm now will it still use the same amoutn of fuel later with larger injectors?
I assume only when the fuel is neded will more be pumped in?
And lastly, when petrol can be smelt from the exhaust, what does it mean?
I've been told it means it's running rich, some say you dont smell anything when it's running rich and that it means it's running lean?
Anybody know the real answer?
Andreas
Any suggestions?
Andreas
