• Tapatalk and Mobile iOS/ Android APPs no longer supported on aussiefrogs.com. Please delete on your device. Use the web interface instead.
Cleaning rims
Matthew
I have 4 second hand 306 rims with a good deposit of what seems to be tar in them, what is the best cleaner for this? Apart from kero and elbow grease looking for anything better?
Ta Ta Tar?
schlitzaugen
I found kero can dull the appearance of top coats in some cases. Wonder if a good ultrasonic bath would do anything.
Matthew
Cool, tyre cleaner is removing most but its hard work. will try Kenco once home, Big bath and expensive those transducers..
schlitzaugen
Yeah, not really an option for the home player.
Maybe you could let it soak in the cleaner a bit? Perhaps blotch it and let it sit with the tyre cleaner on top for a little, might help penetration and reduce the amount of scrubbing needed. A paper towel soaked in the cleaner and stuck on top of it?
Ta Ta Tar?
I have always removed tar with a rag soaked in diesel. Just need to give it a wash with soap after it is removed.
Matthew
Its not tar now, that came off easily its like brake dust barnacles, hard little drops that require physical removal with brake cleaner, done slowly!
I am sure I have used other brake cleaner that seems to do this easily, but its at home 1400km away.
