haha yes! at a leisurely pace as well..you going southbound or overtook me? top speed up the big dipper was 60...
I have a billet pulley ready to go on mine in the next couple of weeks along with new belts, tensioners & water pump. How can you tell if the crank pulley has slipped?
Finally! I've been waiting on a solid crank pulley from England and its arrived.. I can now start on the big backlog of work. Did get my wiring harness, ecu and injectors eventually. All that's left is the oil gauge adapter, fit timing belt kit and new manual tensioner, put the engine in the car, wire it up, manifold on, replace my fuel hose from the tank with pipe I borrowed of the 200 205 wreck, fit coolant hoses subframe on and (hopefully) that's it! Might need a shortened radiator..
Can you tell me where you got the wiring harness?
