Many thanks @Ken W - I've ordered the part. Hopefully it resolves my issue! I'll keep everyone posted ...Yes this is the electronic heater controller for your car. I bought one from this ebay seller a month or so ago as he was making some claims about quality and offered a 12 month warranty and the controller he sent did work OK. There have been other who bought cheapie ebay clinese controllers that havn't worked when delivered.
HEATER BLOWER MOTOR FAN RESISTOR FOR PEUGEOT 307 407 Citroen C3 C4 C5 C6 6441.S7 | eBay
OEM PART NUMBER: 6441S7, 6441. Easy to install, fit for PEUGEOT 307 407 Citroen C3 C4 C5 C6. 1 Blower Motor Resistor. We promise to solve the problem for you. Made of high quality aluminum and ABS for maximum durability.www.ebay.com.au
Here is the parts diagram showing the controller as item 10.
Cheers, Ken
And my saga sadly continues … installed the newly received controller (see first photo below - unlabelled controller is the new one) and while it provided fractionally more airflow when the aircon was on auto, the airflow was constant across all the fan speeds when manually set (even at zero fan speed)! I remember reading in this and other forums that the inability to control the fan speed indicates the controller is on the way out - before I contact the seller about this potentially defective controller, anything else I should check?I can confirm that cheapie Chinese controllers do not work. Asking for a replacement is pointless, as the replacement won't work either...
That sounds like exactly what happened to me . My controller looks very different (it is for an XM or 605), but it sounds like they both came out of the same shonky Chinese factory. External appearance was perfect, but just like yours it produced a consistent output voltage across all settings, even the Off setting!And my saga sadly continues … installed the newly received controller (see first photo below - unlabelled controller is the new one) and while it provided fractionally more airflow when the aircon was on auto, the airflow was constant across all the fan speeds when manually set (even at zero fan speed)! I remember reading in this and other forums that the inability to control the fan speed indicates the controller is on the way out - before I contact the seller about this potentially defective controller, anything else I should check?
Thanks everyone …
Hi Ken, yes I was wondering about that (potential climate controller issue). I've already searched high and low for a better 6441S7 and while there are two options - ssg.asia and from Landmark Wreckers which Citroen at Roselands (Sydney) very kindly pointed me to (http://www.landmarkspares.com.au/fo...6441S7/XC8TBC/details?fr=13&fd=3000&ft=7&fb=0) ... - but the last thing I want to purchase the part and the same thing happening ... anyway if you could assist with some voltage figures from the climate controller, I would really appreciate it - thanks.Well it sounds like your fan current controller might be ok and it is a problem with the climate controller. The way to check that is to back probe the control wire that is going to the fan controller (the thin wire on the connector) and see what voltage it send at the different fan speed settings. I might be able to check mine so there are some figures for you to compare with.
Cheers, Ken
Happy new year Ken … hey my kids have been killing me with complaints of the p***weak aircon - not helped by the black leather interior so easily becoming a heat sink despite my best efforts of parking in shade and with windscreen shade etc …Well it sounds like your fan current controller might be ok and it is a problem with the climate controller. The way to check that is to back probe the control wire that is going to the fan controller (the thin wire on the connector) and see what voltage it send at the different fan speed settings. I might be able to check mine so there are some figures for you to compare with.
Cheers, Ken
Ken - can’t thank you enough. I’ll have to find some time soon to test this but first of all dig up the references in this forum on how to pull out the A/C controller. Will update!Sorry, It had slipped my mind. So we are finally having a day with outside temperature lower then 28 degrees and the C5X7 is at home. So I ducked out there with some cardboard to kneel on and my multimeter, back probed the white wire on the fan speed controller with the red probe and connected the black probe using an alligator clip lead to the outer sheeth on an adaptor plug coming out the cigarette light socket. Here are the results.
Ignition off - 0.006 volts
Ignition on - 0.007 volts
engine running with fan not running ie 0 segments - 0.025 V
1 segment - 3.1 Volts
2 segments - 3.67 V
3 " - 4.1 V Fan still pretty quiet up to this setting
4 " - 5.12 V Starting to get loud now
5 " - 6.03 V
6 " - 7.16 V Definitely loud now
7 " - 8.51 V
8 " - 11.3 Volts Now making a huge noise
So what Voltage is you A/C Controller sending to the Fan Speed Controller at the different settings
Cheers, Ken
Ah that makes sense - thanks Ken. I’m quite proficient by now pulling out the fan speed controller . This is good advice as it’s probably a lot quicker for me to check now.You don't need to pull it out yet. I just pushed the red meter probe into the hole in the connector on the fan speed controller that the white wire goes into. That is enough to get good enough contact to read the control volage coming from the A/C controller.
To remove the controller, you need to turn it a little anti-clockwise and then it lifts out sideways. Look for a slot that will take a large slotted screwdriver and use that to rotate the controller. Take a picture of the orientation because it will only go back in in that position.
Cheers, Ken
Hi Ken - I think I could be doing it wrong as I’m not getting a reading (ignition on) - see photos. The controller has to be disconnected from the connector? And is this white wire you’re referring to? Also I’m using the grounding nearby for the multimeter black cable - is that not sufficient?You don't need to pull it out yet. I just pushed the red meter probe into the hole in the connector on the fan speed controller that the white wire goes into. That is enough to get good enough contact to read the control volage coming from the A/C controller.
Cheers, Ken
I was admittedly in a rush (was literally sweating litres in the humidity) so when it cools down I’ll check the connections again, this time with the connector unplugged but also dial the fan speed up. Thanksred wire probed, i.e stabbed through insulation, looks like alligator clip on the insulation only.?
also your meter may not be sensitive enough until say 0.1 volt reached, so you may need to dial the fan speed to see any change
Hi.The red lead on the multimeter is plugged into the Amps socket. You need to move that to the Volts V socket if you want to measure Volts.
