Do you really even use the fog lights? I cant imagine you get much fog even in Ballarat?
But if you're dead keen on keeping them functioning (for the one or two times a year tops I imagine...) and you're not wanting to buy from china, you'll have to spring the dollars for an OEM one, or get one from pick apart or something.
I've never needed them ... well ever in ballarat. If the fog is so thick I need them, I'm getting off the road. You need to crawl along at about 20km/h if your using foglights .... at this speed, I'm going to have someone run up my @rse doing 60+km/h blindly.
At those prices it could be worth checking your Peugeot dealer, or EAI, the part number is 6216.H0The fog / cornering light on the Peugeot 2008 has blown on the LHS.
According to the owner’s manual they are PSX-24W.
Hi.Did Mitsubishi make the 2008?
Someone posted on this forum about an online supplier that they sourced their bulbs from. Can you please repost this.
May have been me...
Powerbulbs - a UK company but they offer free shipping to Australia if you spend over about $28. (Probably a UK Pounds trigger price that varies with exchange rate.) - Just looked it up, it's UK15 Pounds.
Don't forget to put in that discount code, currently it's SHINEON and it takes 21% off the total. This makes it $26.29 per bulb and if you buy two, postage will be free. (exchange rate will vary constantly, so price may fluctuate a little by the time you click the link...)
I've found them great to buy from.
And about LEDs: I'm not so certain that fitting LEDs would be a problem with FOG lights - true FOG lights are quite different from driving lights, they have a wide, diffused spread of light, the reverse of driving/spot lights which have a long, penetrating beam. The whole point of proper fog lights is acceptance that a powerful straight-ahead beam will just bounce back off the fog and dazzle the driver, so the idea is a wide spray of scattered light that picks up roadsides, it does NOT try to beam all its light directly in front of the car. This diffuse light must be mounted very low on the car, to try to shine through the still layer of clear air that often sits below a layer of fog. I suspect that these LED bulbs would work very well in a true fog light, with lens and reflector designed to direct the light wide and low.
However I suspect many modern cars' "fog lights" are just low mounted spot lights, with a strong penetrating beam that is useless in the fog. They are there to decorate the car and make the buyer feel like that are getting something extra. My Peugeot 307 was like that, the standard factory "fog" lights were bloody hopeless. Before that I had a TR Magna with Hella (Or Narva?) rectangular fog lights that did a good job in the fog, and my partner had an SB Barina with cheap Hansa branded oval fog lights I fitted, they were under $50 a set and were bloody amazing, never seen anything better in foggy conditions. (We live in a very fog-prone area, so it matters to me.)
It is illegal to drive with fog lights on except when there is rain, snow or fog (in Victoria at least) and under those conditions, properly fitted real fog lights are not dazzling to oncoming drivers.
Trouble is, too many duffers drive with them on in no fog, or fit driving lights and use them as fog lights.
Hi.May have been me...
Not sure if the law has changed, but not too long ago it was illegal to retrofit LED bulbs into a light/reflector designed for halogen ones anyway.
It's to do with the way the light is dispersed.
Like many automotive accessories on the market, it's not illegal to sell them, just to use them.
naaa, they just know the road, probably. Used to follow the petrol tankers on Geelong Road, they went like the wind regardless, they could have been up 'n down the same bit of road four times a day ! Learnt this one from a retired petrol tank driver....The heavy trucks thundering through night pea soupers at speed seem to be getting some benefit from their fog lamp arrays.
I thought it was the distance of the filament from the base that determines the focus of the beam, and as noted by @Greenpeace a LED in the same reflector housing is likely to not disperse/focus the beam in the same way.globes or lamp have any shielding or cut-offs to shape the beam
Hi.eBay is cheap 2 for $10 free postage
2x Xenon Halogen 12V Light Super Globes H7 Lamp Bulb White 55W Headlight Car | eBay
1 pairs x Xenon Halogen Globes. Power: 55W. Material: stainless steel lamp holder glass foam.www.ebay.com.au
