BE3 Box Talk
Hi, although you got no response theye are far from identical, having both a variety of diff and gear ratios.
I think you will still find info by searching the technical forum as it will have originated before 2006 (data shouldn't be in the lost lot). Alternatively sites like 205 drivers in the UK will have lists of the combinations.
Peter T probably has a list at his fingertips but I can't find mine.
Jim
Here's a list of Pug/Cit ratios-
Gear ratios and speeds for BE3 gearboxes
ratios
('box/FD) 1st 2nd 3rd 4th 5th 6th FD
205 Diesel 1.8 GRD 3.31 1.88 1.28 0.97 0.76 3.47
205 GTI 1.6/1.6 3.31 1.88 1.36 1.07 0.87 4.06
205 GTI 1.6/1.9 3.31 1.88 1.36 1.07 0.87 3.69
205 GTI 1.6/mi16 3.31 1.88 1.36 1.07 0.87 4.43
205 GTI 1.9 Gutmann 2.92 1.85 1.36 1.07 0.81 3.94
205 GTI 1.9/1.6 2.92 1.85 1.36 1.07 0.87 4.06
205 GTI 1.9/1.9 2.92 1.85 1.36 1.07 0.87 3.69
205 GTI 1.9/mi16 2.92 1.85 1.36 1.07 0.87 4.43
206 GTI 180 2.92 1.85 1.36 1.07 0.87 3.69 4.29
306 GTI/S16 2.92 1.85 1.28 0.97 0.76 4.43 4.43
306 gti6/gti6 2.92 1.87 1.41 1.15 0.95 0.80 4.05
309 GTI16 (90-91) 2.92 1.85 1.28 1.03 0.76 4.43
309 GTI16 (92-93) 3.42 1.95 1.36 1.05 0.85 4.43
405 1.6 carb 3.25 1.85 1.28 0.97 0.76 4.19
405 1.9 carb 3.25 1.85 1.28 0.97 0.76 4.06
405 SRI / 1.6 GTI C/R 3.31 1.88 1.28 0.97 0.76 4.06
405 T16 3.42 1.82 1.25 0.97 0.77 3.93
mi16/1.6 2.92 1.85 1.28 0.97 0.76 4.06
mi16/1.9 2.92 1.85 1.28 0.97 0.76 3.69
mi16/mi16 2.92 1.85 1.28 0.97 0.76 4.43
Xantia 2.0 SX 3.46 1.36 1.07 0.80 0.76 4.06
Xantia VSX (s16) 3.46 1.87 1.36 1.07 0.80 4.27
Xsara VTS 2.92 1.86 1.28 0.95 0.74 4.43
ZX (CB) 3.42 1.81 1.28 0.97 0.76 4.29
ZX (CL&CJ) 3.46 1.85 1.36 1.07 0.87 3.75
ZX 16v 2.92 1.85 1.28 0.97 0.76 4.43
ZX Volcane 2.0i 3.46 1.85 1.36 1.07 0.87 3.59
custom 3.31 1.88 1.36 1.07 0.87 0.00 4.43
(1.9 box with 4th, 5th from mi16, 6th from gti6 and mi16 final drive)
Try it yourself - pick different gear ratios for the "custom" row and see the outcome
Change the values in red on the lower tables to customise the results
mph/1000rpm
('box/FD) 1st 2nd 3rd 4th 5th 6th tyre setup
205 GTI 1.6/1.6 5.0 8.8 12.2 15.5 19.1 width (mm) profile rim (inches)
205 GTI 1.9/1.9 6.3 9.9 13.4 17.1 21.0 195 50 15
mi16/mi16 5.2 8.2 11.9 15.7 20.0
205 GTI 1.9/1.6 5.7 9.0 12.2 15.5 19.1
custom 5.7 8.1 11.2 14.2 17.5 #DIV/0!
mph@redline My redline is 7200 rpm
205 GTI 1.6/1.6 36 64 88 112 138 0
205 GTI 1.9/1.9 45 71 97 123 151 0
mi16/mi16 38 59 86 113 144 0
205 GTI 1.9/1.6 41 65 88 112 138 0
custom 41 58 81 102 126 #DIV/0!
rpm@Cruising I cruise at 90 mph
('box/FD) 5th 6th
205 GTI 1.6/1.6 4712 0
205 GTI 1.9/1.9 4283 0
mi16/mi16 4491 0
205 GTI 1.9/1.6 4712 0
custom 5142 #DIV/0!
ratio differences
('box/FD) 1st-2nd 2nd-3rd 3rd-4th 4th-5th 5th-6th
205 GTI 1.6/1.6 -43% -28% -21% -19% -100%
205 GTI 1.9/1.9 -37% -26% -21% -19% -100%
mi16/mi16 -37% -31% -24% -22% -100%
205 GTI 1.9/1.6 -37% -26% -21% -19% -100%
custom -43% -28% -21% -19% -100%
upshift RPM I shift up at 7300 rpm
205 GTI 1.6/1.6 4153 4965 5526 5703 0
205 GTI 1.9/1.9 4146 5281 5743 5936 0
mi16/mi16 4146 5281 5743 5936 0
205 GTI 1.9/1.6 4146 5281 5743 5936 0
custom 4146 5281 5743 5936 0
Thanks fellas
I have a 1999 model pug 306 N5 (1800cc) gearbox I got the other day and am going to put it in my BX 16 valve which has a crunchy 3rd gear, it had a chipped tooth that got worse after a track work out.
Im not that cluey at all on BE3 gearbox ratio's, is it worth sorceing a genuine Mi16 box? I have read on UK and Peter Taylor sites that a 205 gti 3rd and 4th are worth adding to a Mi16 gearbox has anyone gone through this process? this car is really just for track use.
I think it's worth getting an Mi16 box & changing 3rd, 4th & also 5th. As you said its a track car & you'll still hit 200kph at peak revs with that combination & it keeps the peaky 1.9 in its powerband.
Not sure what ratios the 1.8 84Kw motor uses, but the modified Mi box is a proven combination.
Well I can modify the box I allready have but I think I will keep 5th the same, wiil be better on freeway driving to destinations
Thanks Dan
Don't want to hijack the thread but im confused...
A BE3 box from a 205 , although the same, has different ratios than a BE3 box from an MI16?
I put the 205 gear box onto the MI16 engine Currently at 100kph the engine is reving around 3000rpm
As for the lots of numbers shown above - does this mean the higher the final drive the less engine revs at the same speed ? I see the ratios are the same, but the final drive is different
I'm having a blonde day when it comes to munbers!:clown:
...I'd do a search but ..uumm there is nothing to search now!
