The motor in the BX16V is nothing fancy, just the detuned XU9J4Z (DFW), the same as fitted to local early Mi16's. It has the standard open sump and a spacer plate. As I said earlier, this combination is the same overall height as the XU10 sump and the DFZ sump.The motor sitting waiting quietly in the wings to which I have access is from a BX16V Citroen. I thought it was an XU10 but it may be a fancy version of the XU9 then? This may have the baffled sump, ( or by 'open" do you mean no baffle?) but should have spacer plate and extended oil pump?
I'm not aware of anyone making extended pickups, other than me. This is only required if you use the XU10 sump and a spacer plate, in order to increase the oil capacity and keep the pickup at the bottom of the sump.
