As Graham Wallis said different gearbox different bellhousing and imput shaft, also bolt on slave cylinder.The 5 speed manual in the GR won’t bolt into the gti engine?
Started to think that it’s not worth itNice 505's!
Why the bother for the slightly bigger engine? But have fun either way
I assume all the parts will bolt straight into the GR body?The best bit about the 505 GTi is not so much the engine but the springs and struts (same as late STi and 505 turbo). The sway bars are also different to the GR. Also the faster steering rack is worth using, if you don't already have power steering ( the 505 turbo had a faster one again, but only available in LHD).
STi/GTi engine is not particularly good. Especially the unleaded version. Motoring writers on the release of the STi in Europe wondered why they bothered as the 2 litre was so good. Bit different here with the 2 litre nobbled by pollution equipment. Just get the pushrod engine running properly, that is remove the pollution equipment fit a new dissy, get the carby rebuilt etc. 123 brand distributors are fully computerised, no moving parts except for the rotor, 16 ignition curves so will suit anything from 203 to 505. In stock for Peugeot in Australia.Started to think that it’s not worth it
Thanks mateThe series 2 struts in a Gr will give it 1.5 neg camber much better turning in, sway bars are bigger too.
Everything will bolt in except the wiring loom is different between series 1 & 2
Need any advice pm me
Cheers BP
I'm aware the received wisdom is that the 2.2 Douvrin is a bit "gutless" when you look on paper the output of the thing (in GTi guise) is about 1kW different to a Mercedes 230 (peak torque comparison has similar miniscule variation). Don't recall the motoring press making similar judgements on the Merc. (or maybe I just read the wrong journals!). I think the truth lies more in what you're asking the engine to pull - don't believe me just pop the bonnet on a 505, if it won't open then sign up for about eight weeks weight training at your local gym - should work just fine after that other body panels presumably just as OTT - I know the tailgate on the wagon is ços I had to use an engine crane to hold it when I needed to repair the hinge. There's massive weight there (1.4 tonnes as compared under 1.3 for the 230) for a relatively small motor to haul around.STi/GTi engine is not particularly good. Especially the unleaded version. Motoring writers on the release of the STi in Europe wondered why they bothered as the 2 litre was so good. Bit different here with the 2 litre nobbled by pollution equipment. Just get the pushrod engine running properly, that is remove the pollution equipment fit a new dissy, get the carby rebuilt etc. 123 brand distributors are fully computerised, no moving parts except for the rotor, 16 ignition curves so will suit anything from 203 to 505. In stock for Peugeot in Australia.
