As part of the restoration of my A110, I have acquired a R8G motor from Rob Sealey and it will be mated with a 5 speed box built by Richard Mann also in Melbourne. It came with the car when I bought it from Neil Tollich in Auckland 2 years ago. A lot of work has already been undertaken and it made its first appearance at our Canberra French Car Day last November with the original motor (Type 688) and gearbox (Type 330). It has passed rego and is on historic plates. It was after the gearbox lost reverse gear last January, I decided that I might as well fit the 5 speed box and a new engine while I was at it. Now I have discovered that I will need to instal a front mounted radiator as predicted by Rob. A "dummy" fitting of the R8G motor showed that while the rear radiator fitted, there was no room to fit the fan so am biting the bullet and have decided to instal a front radiator with all the plumbing that this entails. Has anyone done this task and re there any pitfalls to watch out for? I note that the suppliers of the gear like Mecaparts, GBS Alpine and Simons Auto all supply the bits including aluminium tubes and rubber hoses (one does supply silicone hoses). I know Al Kelly went for stainless steel for his rally Alpine but does any one have any experience of the type of tubes that should be fitted and if it is worth going for silicone hoses over rubber?
